Timing Belt
I'm trying to make a timing belt for my engine block and I have no idea how to start off, Does anyone have suggestions on how to create such a thing; something to align with all the teeth and make it spin / rotate with other gears and other teeth?
Thanks!
Link:
Thanks!
Link:
https://cad.onshape.com/documents/a7db7002771dafcfc6ee1e89/w/438796e7a338ae7de57d6502/e/4cf21d2e2d4f6615598a04e6?renderMode=0&uiState=64e285cd0487c867774b6c57
eric_pesty Member Posts: 2,303 PRO
Here's a quick example showing how I would figure out the location of the teeth of each pulley and how to build a simple assembly. You would still need to add an "idler" in there to get the total belt length to be an even number of teeth (and a commercially available one too...) but the process would be the same.
https://cad.onshape.com/documents/611c3ab26a69f5d5bdb27f57/w/df7d43f0f9ca03812a1467a3/e/3154b6231086cff8c857332f
The physical "belt" part is only going to be "visual".
As far as aligning things in your design, I am not aware of a tool that will do this for you. You will have to figure out the angle of the pulleys relative to your shafts "manually" to match the tooth spacing.
I would start with a sketch showing the locations and "pitch diameter" for each pulley, pick the first tooth on your main pulley and then create an arc-line-arc that ends at and adjustable angle on the next pulley and adjust until that length is a multiple of teeth spacing. Then repeat for each pulley.
A good tip is to use "measure" variables after your sketch and enable the "final" button when editing your sketch to see the effect in real time.
I'd add a large diameter representing the outer pulley diameter and then offset the belt path to represent the belt thickness.
In another sketch, I'd detail out the teeth. I wouldn't combine them in one sketch (belt/pulley layout & tooth details).
If I'm on the clock, I wouldn't ever show the teeth.
