Exporting and Importing with history intact
kartik_1
Member Posts: 6 ✭
Hello,
Is there any way make sure that when exporting and importing a part the operation history is intact? e.g. If I import a part into Onshape the operation history of that part also comes along?
Thanks,
Kartik
Thanks,
Kartik
-1
That said, Onshapes initial set of direct editing tools allow you to work with models that lack history very effectively. This capability will improve.
Can you expand on what you mean by "history"? Are you hoping for a format that has all of the branches/versions and workspace history or are you interested in a system that still has the parametric design?
Thanks you!
With warm regards,
Viru
https://cad.onshape.com/help/#transform.htm?Highlight=transform
That's a solution only in those cases where the derived part's desired location can be prescribed dimensionally, is it not?
In practice, inserted parts often need to "follow" the movement of related parts, in other words, their position needs to be specified in a way which is live rather than dead.
I hope you will extract another rabbit from the capacious Onshape hat, and show me I have this wrong!
I believe he was referring to the possibility of exporting & importing native OnShape files so the feature tree is in tact.
This is an important point & one where other packages have an advantage over OnShape.
#1, there are legal requirements in some countries for companies to keep critical records & data backed up for 7 Years. In some circumstances CAD data will fall into this requirement.
#2 - if for example, you let a subscription lapse for a year or two ( & it can happen - it happens with other packages). When you decide to opt back in again how can you access your work from the previous years? Or has that all gone into cyberspace?
I know the suggestion will be "export as Parasolid or STEP".
A few issues there -
These are dumb solids & all constraints & intelligence are gone.
Modification of these is not always so easy.
Even SE Synchronous Technology has occasional issues with these.
As I am aware there is still an issue with the STEP translator......hopefully this will be fixed soon :-)
What are the backups like & how often at OnShape?
What security is utilised? Hopefully a little better than icloud
Knowing this, it would not be necessary to download your native files.
Exporting of Parasolid and STEP is still a critical ability.
I have experienced a translation problem with the STEP translator & the guys are working on it. They'll get there.
Something more of an issue is other translators such as SAT & STL.
If you have to send to a tool maker that uses, Autocad, you need to export SAT (mind you, I personally wouldn't have a lot of faith in anyone who relies on Autocad).
If you want to have 3D printing done, you need to translate to STL.
