Having trouble mating Cylinders to extruded holes in side of another cylinder
Hello. Im new to onshape and im having issues with mate function.
I revolved to make 3 cylinder's.
Then i made a plane on surface of and extruded to make 2 holes in my master part.
Now i need to mate (and mabe flip) the 2 parts to face of master part..
Very frustrated.
Very frustrated.
Make all three parts with a single sketch and three revolves in the same Part Studio, then Boolean subtract the smaller cylinders to make the holes in the big one. When you inster them all into an assembly, use a group mate. It's easier to define the relationship among parts in sketches rather than mating them in assemblies.
It seems like a couple of simple fasten mates should do the trick. Have you tried that, are you getting an error or what?
Drawing the parts in one part studio "in place" and grouping them is an option but not necessary (especially if you already have your parts)...
You could always add explicit mate connectors in your parts (see https://cad.onshape.com/help/Content/mateconnector_a.htm?Highlight=mate connector) to make things easier (although that really shouldn't be necessary).
https://cad.onshape.com/help/Content/mate-fastened.htm?Highlight=Fastened mate
Then do the mate help section that dirk linked above.
Is this what you are after?
https://cad.onshape.com/documents/440d89b9add2ff783dacabc3/v/a952e467c4d37bd970d6eaca/e/59c8f2ad332845e02d802e6c
