Eddie Robb
I have been asked to change the orientation of the dimension value from horizontal to vertical on a drawing i.e. the 150 value on the drawing below. Can this be done?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    If you use an ISO drawing border it will set everything you need.
  • eddie_robb142eddie_robb142 Member Posts: 2 EDU
    Thank you Neil
