Eddie Robb
I have been asked to change the orientation of the dimension value from horizontal to vertical on a drawing i.e. the 150 value on the drawing below. Can this be done?
NeilCooke Moderator, Onshape Employees Posts: 5,891
If you use an ISO drawing border it will set everything you need.Senior Director, Technical Services, EMEA0
