In trying to get the spacing at 40 and the thickness at 22, using transform was going to be too slow with regards to how I laid out my features. So I went back and modified a number of features to get it to your 3600 x 2500 with a 40 on the space and 22 on the thick. In doing so, I ended up with the original amount of full rings around the center hump.
With a spacing of 40mm and a thickness of 22, you’re not going to end up exactly with 3600mm. It’s going to be a tiny bit less.
58 X 62 - 40 = 3556
About 7/8 of an inch shorter on each end
Spend some time slowly rotating left to right and compare it to that with the original aspect ratio
Twitter: @BryanLAGdesign
