Insert a part into assembly form 'Public Documents' and can't give it a name in the BOM
patrick_shea
Member Posts: 63 ✭✭
I have a simple project, and wanted to insert some Pocket Screws I found in Public Documents, but I can't give them a name in the BOM?
Here is the project...
Pat
PAPER TOWEL HOLDER | Assembly 1 (onshape.com)
Pat
NeilCooke
Moderator, Onshape Employees Posts: 5,927
You need write access. Therefore if you want to change a description, you'll need to make a copy of the document first.Senior Director, Technical Services, EMEA0
Patrick
