Improvements to Onshape - September 1st, 2023
cody_armstrong
Moderator, Onshape Employees, Developers, csevp Posts: 213
It has been exactly 3 weeks since our last update, and like clockwork, we are back with another long list of improvements requested by you! So without further ado, let's dive in.
GENERAL IMPROVEMENTS
LIST VIEW
List view is a new, intuitive way to navigate your Onshape data based on your product's structure, rather than Documents.DRAFT IN RIB FEATURE
You can now add Draft directly within the Rib feature.ANGLE REFERENCE IN FRAMES
You can now define an angle reference when creating Frames in Onshape. This is useful when you want to define the angle of a Frame feature relative to other geometry.MID PLANE IN THIN-EXTRUDE AND THICKEN
You can now define both Thin-extrude and Thicken features with a Mid plane offset. This allows you to create geometry that represents the center and quickly offset it equally in both directions.CATEGORIES IN BILL OF MATERIALS
Categories can now be added to your Bill of Materials in Onshape.COPY/PASTE FROM PART STUDIO
You can now copy a Part from a Part Studio and paste it to an assembly within the same Document. In the past, this was limited to parts already inserted into the assembly.CONVERT BOOLEANS AND TEXT PARAMETERS TO EXPRESSION
You can now convert booleans and text parameters to an expression. Controlling booleans and text parameters with expressions can be especially useful when creating configurations.IMPORT APPEARANCES
You will find a new option when importing to "Import appearances." It is on by default (meaning appearances are imported by default) but can be unchecked if you do not want the imported model's appearances.PUBLICATION IMPROVEMENTS
If you share (with export permissions granted) a Publication using Link sharing, the person you have shared with will have the option to print. This can be useful if you share with someone that does not have an Onshape account and they want to create screenshots for documentation, sales, or marketing purposes.DRAWINGS IMPROVEMENTS
GEOMETRIC TOLERANCE IMPROVEMENTS
You can now add information to all sides of a Geometric tolerance symbol.CIRCULAR CENTERMARKS
You can now insert Circular centermarks in Onshape Drawings. This is especially useful for defining bolt circles.EXTERNAL THREAD IMPROVEMENTS
External threads now show a more accurate transition in Onshape Drawings.FEATURESCRIPT IMPROVEMENTS
WHERE USED FOR FEATURE STUDIOS
Where used now supports Feature Studios. This allows you to quickly find any Part Studio (or Feature Studio) where a specific custom feature has been inserted.PROFESSIONAL IMPROVEMENTS
REASSIGN TASKS
Onshape Professional and Enterprise users can now reassign tasks. In the past, the task needed to be deleted and recreated. Only the task creator and company administrator can reassign a task.ENTERPRISE IMPROVEMENTS
TEAM FILTER FOR ACTION ITEM ANALYTICS
You can now filter Action Item analytics by the team responsible for them. This gives you an easy way to see outstanding Tasks that belong to a specific team.Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this update, please see the changelog.
Remember: The updates listed here are now live for all users when creating new Documents. Over the next few days, these features will also be available in Documents created before this update9
https://thesmoothcut.com/
I was starting to think they had forgotten about configurations.
Good work Onshape
Website: ovyl.io
(Thanks Dan Jacobs)
I didn't think it would happen so soon!
Website: ovyl.io
Website: ovyl.io
Is it possible to include unreleased items and items without part numbers in the list view?
In early concept designs we don't use part numbers and many concept parts are never released.
We also don't release vendor components.
ugh you're right I completely jumped the gun on that. I've been waititng for the ability to apply logic to suppression. This is still cool but not going to save me hours apon hours of work around yet.
https://youtu.be/6HoMM2A3fm4
Website: ovyl.io
Thanks Evan. That was very clarifying explanation.
You know the next question that will come. Can the part number be retrieved as text for engraving or embossing on a part?
Axel Kollmenter
