Surface Blend Basic Failure
Stuff like this not working I dunno, I like Rhino better now. Very simple split cylinders with naked edges can’t be blended together. I take two extruded cylinders, delete a cap from each and cannot then form a blend surface between those naked edges using Blend.
And it still works without even removing the ends first to generate Rhino-like naked edges.
