Mirror problem
Hey,
When I try to mirror a part studio piece, it says that the mirror did not generate properly: boolean operation failed to return a valid part. Which is weird because I use the exact same method in another part (I split the piece in half via a removing extrusion so that I can mirror a simmetric counterpart).
If someone could take a look and help me out, I would be very grateful:
https://cad.onshape.com/documents/6dc1a5a8c1c0a1dfd46a703c/w/17234f5442e7146dae2bb24a/e/0bd9d7c0500e25589635ea99?renderMode=0&uiState=64f52b35a53d1304f88ca7ff
    You'd have to make the doc public, but it's most likely due to the underside fillet at the front of the part having a small edge?
  • Hi @NeilCooke, I'm pretty sure the document is public - could you check again and let me know? Thanks for taking the time!
    No, link share is not the same as public - go to the share dialog and then the public tab to enable.
  • Got you! It should be fixed now. Sorry about that. Please let me know.
