Philip Thomas challenged us to do a Dodecahedron in less features. I did itin 4 features and 2 var.
How do I contact Philip Thomas to meet his Dodecahedron challenge.
Is there a peer to peer message board , where I can call him out ?
emagdalenaC2i Member, Developers, Channel partner Posts: 863 ✭✭✭✭✭
You can mention @philip_thomas in a post, so he will be notifyUn saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común5 -
lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,011
Click on his avatar in the forum to go to his profile page and then you can message him directly.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5 -
@tommie_berry nice model
I try to improve it a bit:- The angle between faces is constant so you don't need a variable for that
- I add the formulas to the length and angle relatives to the length of the edge:
- Also change a bit the second sketch to remove fix constraints
https://cad.onshape.com/documents/f7b9f47a583fa0a31a4e212e/w/1bdf4751f06909ed3b66958c/e/39b198889376a4fb2553415c
Extrude depth = #Lado*sqrt((50+(22*sqrt(5)))/5)/2
Extrude draft = 90deg-acos(tan(18deg)*tan(54deg))Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común6 -
steve_shubin Member Posts: 1,111 ✭✭✭✭
tommie_berry said:I am 71 today and I have no memory of this thread …Funny how the memory isn’t as sharp as it used to be
Happy Birthday to a fellow old timer !!
So, now you can change the length of the edge and it works finehttps://cad.onshape.com/documents/f7b9f47a583fa0a31a4e212e/w/1bdf4751f06909ed3b66958c/e/39b198889376a4fb2553415c
One more feature to get a Dodecahedron as sheet metal part
It most definitely is an interesting problem! There was a whole thread a couple of years ago that @lougallo and others were all involved in. Here it is if you are interested in seeing the solutions of others;
https://forum.onshape.com/discussion/1419/does-anyone-have-a-dodecahedron-tutorial-or-can-comment-on-techniques-to-make-one/p1
In the end, John Sorrels (i dont know his forum name) won because he knew feature script was coming and did it in one feature
I searched the forums for 'dodecahedron' and had a good laugh when this came up!
I like your 'analytical' (variables and equations) solution.
Props also to @emagdalenaC2C for the first 'sheet metal dodecahedron'!
Also - gratuitous mention of @ilya_baran as he was another guilty party in the aforementioned thread.
Glad everyone is having fun!
ps - found it - @jon_sorrells
What about the "Five Cubes" polyhedron.
A construction that defines it is:
- Start with a cube extrusion of a square,
- Define axes which are the four diagonals between opposing corners.
- copy the cube and rotate 30° around each of those axes, thus creating four new cubes
that intersect and each main vertex is common between three cubes
The bit I can't work out is how to define the axes - it would be good if it was possible to define an axis as normal to a plane through a point or through two points.
I bet someone here would have pointers.
I was able to get it by referencing the equations on Wolfram here, I used my Freeform Spline feature to make the axis with a 2-point spline. Point one is on the origin and point 2 is (1, φ, 0). From there it's just a circular pattern at 72°. Here's my example studio.
Independent Onshape Consultant | Industrial Designer
