Rack and pinion relationship tool
When creating a "Rack and Pinion relationship", is there a trick to adjust the the pinion and/or rack so the teeth mesh properly?
  • S1monS1mon Member Posts: 4,081 PRO
    Edit the mate connector for the gear and add a rotation around Z of the appropriate angle (probably 1/2 a tooth or something related).
  • paul_schnurpaul_schnur Member Posts: 3 PRO
    Thank you S1mon
    Thank you S1mon
