Use a part (downloaded) in another part I that designed to create a feature
I looked at the online On Shape manual, YT and Google searches for the answer to my question but I am pretty sure that I am not using the correct terminology or this is not possible.
I have designed a small electronics box for my most recent project, the project will be powered by USB C. In the past I would measure and guestimate to make a hole in the wall of the box for a feature. As I get more comfortable with On Shape I am trying to learn better ways to accomplish tasks. So I found a female USB C step file on GrabCAD that fits my needs. What I cannot figure out is how to import this into the electronics box drawing, once imported I want to use the USB C drawing to extrude an opening in the side of my electronics box so when I print the box its a clean fit.
In my quest to figure this out I have learned how to import the step file, create an assembly and I understand how to join the mating surfaces to join parts in the assembly. I don't think what I want to do would be done in an assembly but am glad I learned that, very cool feature!
In other words I would like to import a part into an existing drawing and use the part to model additional features. Ideally creating a hole with the existing part to ensure a good fit. I wish I could explain it better but please ask if I left things unclear. Maybe this isn't possible???
If I understand right? One of the tools you can use is in context. Insert your USB-C into the assembly and mate it to whatever it is connected to then edit your electronics box with incontext editing.
Here's a practical example of in-context editing:
FYI for vocabulary: "drawing" = the 2d piece of paper that shows a design with multiple views, dimensions, your name for credit, a revision block, etc. A lot of people on youtube are calling everything to do with CAD "drawings". It is incorrect.
"solid model" is the more appropriate term. Or, the onshape term is "part studio" for parts, and "assembly studio" for assemblies.
Wayne,
This is exactly what I was looking for. Thank you for the help!
Eric, Thanks for the video, that really helped to figure out in-context editing!
