Disobeying dimension
in General
Hello all. I'm in the process of learning to utilize variables and configuration tables. My project is a cable gland based on cable diameter. I've come across a glitch I need to solve before I can move on. Up to this point values of the part (body) follow the configuration selected (which is 7mm) except for the dimension from the centerline to a vertical line in the sketch 'compression rib'. The value assigned is (#I_D/2)+.5mm which should be 4mm but the resulting value is 3mm. I have the suspicion that the order of my build is wrong. I've spent too much time going over this suppressing features, deleting constraints , etc. to discover my error with no success so I've come here to seek help as to where that error is; I'd appreciate a bit. - Scotty
https://cad.onshape.com/documents/044b2e03ce23f977ae9034ad/w/783efb8244ac9be1cc100338/e/637a137923b82858f326e0f7
Is the ID (identification or inside diameter?) that of a common size fitting with different wires that will pass through? IE the gland fits in a common punch out. If there are different sized fittings then I would think the nominal size or designation would would be a convenient start point. From which the inside diameter can be associated according to wire size with that when selected then other dimensions can be calculated from that. Sequence to assign variables is important and watch your formatting in the configuration table.
#xx+3mm Note the "mm"
Try this sample now and see if it helps. The wire ga is selectable with other dimensions that are calculated. I like named variables even though it's not a requirement because the name is applied to to column headers instead of repeating 'length' & 'dia' as header names.
Your table uses #I_D as the first entry with the rest of the column filled in manually. This column should all be filled in manually to make a selection. Note. The whole column in sample refers back to #I_D. That's why you're not getting changes down stream.
Hope this sample helps. Gotta hit the sack.
https://cad.onshape.com/documents/044b2e03ce23f977ae9034ad/v/d5c52146711435c82ccafde4/e/637a137923b82858f326e0f7
Cheers, Glen
Looks like it opened at an old version. Just need to go back to main.
I was looking back to see the original intent.
