Mate Connectors Need Some Love
S1monS1mon Member Posts: 3,819 PRO
edited September 2023 in Product Feedback
I've become more and more dependent on Multi Mate Connector from @konstantin_shiriazdanov. Unfortunately he doesn't seem to be active and maintaining it any more.
MMC is great for adding MCs to a bunch of parts all at the same place, and it also has some features to allow mate connectors to be placed in locations which can't be easily done with the built in tools. However, it's not great at keeping the internal IDs consistent, so I end up having to redo mates in my assemblies more than I would like. This is a great example of how, as users, we come to depend on custom features because important functionality is missing in Onshape, but without maintenance, these custom tools can be frustrating.
In general, there are so many places where mate connectors could use some little improvements:
  1. Allow the standard MC tool to add stable MCs to more than one part at a time (i.e. replace most of what I use MMC for) Ability to assign one mate connector to several parts at time
  2. More options for placing MCs on curves and surfaces: Mate Connector Normal to End of CurveMate Connectors Normal to Rounds and SurfacesAllow Curves to Use Mate Connectors as VerticesAlign mate connector with primary axis normal to curve or non linear edge
  3. Allow mate connectors to belong to a sketchMate Connectors in SketchesAllow mate connectors to be owned by surfaces and curves
  4. Measurement improvements: Measure Angles from Mate ConnectorMeasure Mate Connector Orientationmeasure between mate connectors in mate connector frameMeasure from more mate connectors (midpoints, centroids, etc.)
  5. More orientation options when creating MCs: Realign Secondary Axis of Mate Connector to a hole or other similar featuresMate Connector definition from another Mate ConnectorMate Connector placed "Between Entity" on two drafted surfaces should lie on the mid-plane, More Primary Axis Options for Origin Mate Connector in Part Studio3 point option for implicit mate connector
  6. Naming/finding: Automatically name mates with name of first part selectedEasier Way to Find Mates Associated with Parts
  7. Improve UX of limit mates: Mate option to flip offset/limit direction
  8. Promoting implicit to explicit (we have some clever ease of use things with variables, now is the time to do this with MCs): Toggle Implicit Mate Connector to Explicit Mate ConnectorKeep Implicit Mate Connector after Use
  9. Enabling implicit MCs in more and more places: Move Face with Point to Point TranslationMeasure Tool: Implicit Mate connector function to measure distance between two mate connectors
These are just some of my key MC related IRs, but there are a ton more.
Maybe because there are so many "paper cut" level annoyances, and many of these don't get a ton of votes, they don't get the focus they need. However, I see them collectively as a ton of opportunities to make small changes which add to more systematic ways to use the power of MCs to accomplish modeling and assembly tasks.
  • Konst_ShKonst_Sh Member Posts: 112 PRO
    Let me ask what is desired behavior for keeping consistent internal id's? It is only affected by owner bodies selection order, I could use slightly improved version of this approach - `forEachEntity` function but that basically all
  • S1monS1mon Member Posts: 3,819 PRO
    @Konst_Sh
    Glad to see you on here.
    What I'm seeing with MMC is that bodies which manage to keep their names and show up in the assembly just fine, but MMC looses track and/or it still creates a MC, but the assembly mate shows the MC as missing.
  • Rhett_RobinsonRhett_Robinson Member Posts: 169 PRO
    @S1mon this list is fantastic! I went through and upvoted any that I hadn't voted on already. Definitely want to see the mate connectors become even more powerful!
    Hm, Honestly I haven't tested it for stability with assemblies, assuming that if MC with same creating operation id is attached to same part in part studio and no regen errors occured then it should be good for assemblies. If it doesn't then whatever goes wrong is occuring outside of featurescript responsibility. Without knowing how exactly onshape defines MC identity we can only guess whats going on there
    @Konst_Sh
    One simple improvement to MMC I'd love to see: the ability to name the mate connector.
    1. Name them all the same with a text input in the feature creation dialog (e.g. "MC origin")
    2. For extra credit, have an option to add the name of the part to the text
    I was also interested in MC naming, but seem that it is also not possible currently in featurescript
  • jonathanb_sydneyjonathanb_sydney Member Posts: 32 PRO
    edited October 2025
    Great list, I recently found the need to be able to move a mate connector from the implicit spot up to a face. It would be good to have some sort of move mate connector to, or offset from, an entity, not just "blind."
    This IR from 2019 kind of addresses this.
    https://forum.onshape.com/discussion/11538/move-mate-connector-up-to-selection
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,036 PRO
    I wrote this in other places, and to OS support, but I'll add it here. Why in the world can't a mate connector reference another MC? Its supposed to be a coordinate system.
    You can pick the tangent of a round to place a MC, which is about the most unreliable reference that can possibly exist in CAD, but can't pick another MC as a reference.
    I end up making dummy sketches simply to place a point, that I then use as a reference for a MC.
    It's as if MC are not meant to be the driving datums, as they are in other cad systems in coordinate system form, but rather as secondary to geometry.
  • lee_harrison288lee_harrison288 Member Posts: 6
    I'm reasonably new to Onshape and not following all the above comments, but I have what I think is a much simpler and more pressing one — why can't mates always be defined in the Part Studio and then go with the parts to Assembly studios? This would be an enormous time-saver for parts that are used in many assemblies, also further standardization in use. Indeed I'd like (for the aerospace applications I do) to be able to lock an exported part so that no other mates can be established on it other than the one(s) provided from the part-studio … to prevent downstream mistakes.
    Related to this is documentation — lack thereof. There are vague references to "different philosophies" of Parts-studio Mates vs Assembly Mates … but no real documentation I can find. And of course there is the question of why do SOME mates established in a Part Studio go though to Assembly? Clearly there are two different classes of mates … why not give them separate symbols, describe their attributes, so at least users understand what kind(s) of mates can be affixed in the part studio, for subsequent assembly?
    Another beef is difficulty of adding some obvious mates, although this may just be because I am a noobie and don't know how?
    • In general — I have a cicular hole through an object and I want the mate at the center of that hole passage … how to do that?
    • I have a circular hole through an object where the surface isn't planar to to the hole (commonly a drill hole through a circular shaft) — how does one get a mate onto that?
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,491 PRO
    When you create an explicit mate connector in a part studio, you have to specify the "owner" part. It will then be available in assemblies for that "owner" part. When you insert items into assemblies that have these explicit mate connectors, you can turn on "snap mode" to mate them to assembly geometry. If there is more than one explicit MC, ctrl cycles which one is used. There's an example of that here:
    For selecting mate connectors in "empty" space, hover over the surface and hold shift to "lock" the selection to mate connectors on this surface. This lets you select the center of a hole for example, works the same with a hole in a shaft, pick the inner face of the hole and you get three options: one at the center of the bore and one each end.
