Correct way to project a derived shape onto a sketch?
stephen_sherwood846
Member Posts: 26 ✭✭
in Drawings
I needed to design a part in a Part Studo (the yellow part shown in the image) which represents a bought component. I wish to accuratly produce a cutout for this part in another part studio. I created a test part studio shown in the image and placed the yellow compent in as Derived.
I tried creating a sketch on the target part but could not see the derived drawing, so I created an offset plane inbetween and created on sketch on this. I had hoped I could simply select the boundary and right click and "use" to project the selected lines on the sketch but that option was not available. In the end I had to redraw the derived part onto the sketch on the plane (it did let me use constraints against the derived object) and then create a second sketch on the target plane where I could then "use" lines selected from the sketch on the plane. From the I could extrude the cutout,
Is there an easier way of doing this sort of thing?
Not sure I completely understand the problem. Here is an example of how I would approach this. No offset planes are needed. Sketch for mating part is on the face of the derived part. In fact the derived part isn't necessarily needed unless you want for organizing.
Don't forget that you can insert the purchased item into an assembly and make the matching part by in context editing. The use function works there also when making new sketches.
https://cad.onshape.com/documents/8176bf42ef782f8303d3ee92/w/9a054da62eb5b27426d906a3/e/c679ef1e23839e4887360c60
