Release drafts visibility
Mathilde_ChoëfMathilde_Choëf Member Posts: 4
Hi!
I created a release draft and need it to be visible by my colleagues but only the approver can see it. Is it normal ? I would like the observers to access it too, is it possible ?
Thank you in advance for your answer,
Mathilde
  • adrian_vlzkzadrian_vlzkz Member, pcbaevp Posts: 296 PRO
    edited September 2023
    Curious about this too, not sure if this is possible. What is the intent of having others view a draft? a potential workaround would be to add an extra step in the Release Workflow, like a pre-review.
    CAD Engineering Manager
    Drafts are per user and cannot be shared (other than with the Administrator).
  • Mathilde_ChoëfMathilde_Choëf Member Posts: 4
    The idea was indeed to have a pre-review by the other team members.
