Detail View Feature
                    It would really help a lot when dimensioning small features in a view to have a tool that will allow us to create detailed views and dimensions on those views.
EDIT: Have not seen this post already requested https://forum.onshape.com/discussion/1229/detail-view#latest Sorry
Nicolas Ariza V.
5
Standards and conventions seem to have changed a lot over the years as far as:
the shape of the boundary on both the parent and detailed views (not just circles anymore!),
the line type of the boundary line, (solid, dashed, dotted)
whether a boundary line is shown at all on the detailed view, and
the wording and location of the note (as in your example) "See Detail E" (sometimes just has "Detail E" or just "E"; sometimes attached by leader, sometimes between arrows in gap in boundary).
I usually show the detail boundary (circular or otherwise) but not always, depending on context.
My boundaries are usually circles or ellipses, but occasionally irregular splines or polylines.
It would be good to have separate control over display vs non-display of the boundary at either end (parent view or detail view)
It's also good to be able to add text to the View Label.
It would also be useful (but only very occasionally) to be able to show a different configuration from the parent on the detail view: this can be an economical way of showing a small group of features which are the only distinguishing feature of an otherwise identical part.
Scale, naturally, should be parametrically linked, exact wording optional.
I like all of these options. but in your looking for a simplified choice I'll start.
There are many shapes that I would need to suit a particular drawing environment. My preference would be to be able to sketch a desired shape and use that geometry chain. We cannot create a sketch yet so for simplicity and having the ability to create a detail view ASAP I would be satisfied with the basic circle for now.
I don't know what or if there is a standard for the boundary line. If there is no standard I would prefer a dashed line, If a standard exists then I would most definitely would prefer the standard.
I'm indecisive about showing the boundary line on the detail view I would like an option but If choosing I would prefer not to have it.
In defining the view I would prefer to just have the letter attached by a leader as the best option. Below the actual detail view I would prefer "DETAIL E". While on the subject below the section views I would prefer "SECTION E-E" instead of the current "E-E".
