Revolute mate limits don't work when a part is fixed.
![erwin_1](https://cad.onshape.com/images/placeholder-user.png)
On a project I was doing I made some revolute mates with limits (Doors in a cabinet).
When trying out with the animation button everything seemed OK. Only when I tried the finished revolute it wouldn't budge!
With the slider mate (drawers in the cabinet) there is no problem.
Started experimenting with a test document ( Test revolute limit Main ) and found that as soon as I fix one part the revolute won't work. Deselect the limit checkbox and the revolute works, select it and it won't work.
I usually fix some base part in an assembly and off-course I had done that with a part in the original document...
Any ideas? Bug?
Any ideas? Bug?
Hi,
The first mate connector must be the one of the fixed part.
Hope it'll help
Hmm ... I copied your model, unfixed Part 2, Fixed Part 1, and the limit mate allowed me to drag Part 2 around in a 90 degree arc using the left mouse button.
In other words, it seems to work as intended.
Strange, with the slider it works both with the triad and without.
Thanks all!
Thanks!
Thanks
