threads
doug_hills
Member Posts: 26 ✭
in Drawings
can anyone direct me to the learning material on how to draft threads? I want to create a thread with a round peak and valley. so when the axis is vertical the thread lines are closer to vertical than horizontal, allowing me to 3D print it in plastic, without support.
In this discussion someone points out a feature script for making threads, but depending on what you're doing, likely overkill:
https://forum.onshape.com/discussion/6476/threaded-hole-part-tool
Here, @Evan_Reese says that an equilateral triangle section prints well for him:
https://forum.onshape.com/discussion/21473/optimized-thread-form-for-3d-printing-featurscript
I admit that I have not yet printed any threads, so I don't actually have parameters to suggest (which would obviously vary widely with your actual printer), but if it were me, I'd probably just for the fun of it start with something like this and mess with the parameters until I got something that worked well for my printer/use case: https://cad.onshape.com/documents/a9cd2a06c0af2da77724e251/v/8c454b7c5e9122ba91e3b66b/e/a2b5865d5e7184cafaeb1758
Website: ovyl.io
Website: ovyl.io
