What is error: NO MERGE SCOPE SELECTED
james_murphy562
Member Posts: 6 ✭
Tried to extrude a surface got ' NO MERGE SCOPE SELECTED'
Suggestions? Murph
Suggestions? Murph
MichaelPascoe
Member Posts: 2,604 PRO
@james_murphy562, at the top of the extrude dialog box, there are some merge options (new, add, subtract, intersect). If you don't want it to merge with anything, select "new" instead of "add". If you did want to merge the extrude with another part, you would need to select which parts you want in the merge scope dialog down near the bottom of the extrude dialog box.
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴0
