Having a part property that evaluates differntly depending on the parts category
Daniel_O_Leary
Member Posts: 7 PRO
Hi All,
I'm curious if I'm approaching this wrong or if it is an onshape problem.
My understanding of the value of having part categories was to allow you to have multiple properties with the same name but evaluated differently based on the part category. So i have set up multiple part properties that have the same display name but are assigned to different part categories, for example i have 4 part categories that each have a property with display name "THICKNESS" because I want this property to be evaluated differently based on the production process I will use for the part. But now the issue I have run into is that when I go to create a BOM template, I go to add a column for said "THICKNESS" property it gives me 4 options for "THICKNESS" and when added only evaluates that property for parts of one of the part categories.
Is there a way for me to accomplish this? ie have a part property that evaluates differently based on the category?
NeilCooke
Moderator, Onshape Employees Posts: 5,987
Hi Daniel - a category is simply a filter to show/hide properties (and each property is unique even if they have the same display name). You can add the same property to multiple categories. Not sure how you would process the result differently though.Senior Director, Technical Services, EMEA0
