Help With Placing Part Into An Assembly
john_hammons643john_hammons643 Member Posts: 17 EDU
Hello....I'm writing for one of my students as I'm not sure what the problem is. The "Bottom Pedistal" part seems to be built fine but it only comes out into a rectangular cube when trying to place it into the assembly "All Together."
Assembly link: https://cad.onshape.com/documents/0e5f09c1a75601d1da1a3fcf/w/502b2726bedce1f15ecafef6/e/4f13b4d0843baa2c3ac489bc
Part Link:  https://cad.onshape.com/documents/c1820b83056da4305be04fe3/w/7b99323117e02fcb7b599c8f/e/d04dacd1ce7fcb1e611f2f11
Can anyone help please?
  • john_hammons643john_hammons643 Member Posts: 17 EDU
    Thank you that's what the issue was....the loft feature was supposed to be a solid not a surface model. Thanks again!
  • S1monS1mon Member Posts: 3,405 PRO
    There are two things in the part studio, a rectangular block and a lofted surface. Perhaps the intention was to loft a solid and add that to the block?
