Help With Placing Part Into An Assembly
john_hammons643
Member Posts: 19 EDU
in General
Hello....I'm writing for one of my students as I'm not sure what the problem is. The "Bottom Pedistal" part seems to be built fine but it only comes out into a rectangular cube when trying to place it into the assembly "All Together."
Assembly link: https://cad.onshape.com/documents/0e5f09c1a75601d1da1a3fcf/w/502b2726bedce1f15ecafef6/e/4f13b4d0843baa2c3ac489bc
Part Link: https://cad.onshape.com/documents/c1820b83056da4305be04fe3/w/7b99323117e02fcb7b599c8f/e/d04dacd1ce7fcb1e611f2f11
Can anyone help please?
john_hammons643
Thank you that's what the issue was....the loft feature was supposed to be a solid not a surface model. Thanks again!0
