Using Boolean to union parts is not working
josh_mccullough080
Member Posts: 24 ✭
in Drawings
Document: https://cad.onshape.com/documents/8a96b7586b7d184eb900a413/w/0a9e7d617806bd2bef2c4ee3/e/60d1dccc1a9f2d16215e7168?renderMode=0&uiState=651dae4c270c522a28d7db62
I'm trying to union parts 2-4 into a single part because I want to them create 3 copies of that part and rotate each 90 from the previous (so there's a copy on each edge of the center square).
When I create the Boolean, the parts are not combined. Is this because they do not actually touch each other? The end goal here is that I will have a single STL exported for 3D printing. So the separate "parts" are not really ... separate parts. But I wasn't sure how else to copy/rotate parts 2-4 if I had them all be added to part 1 instead.
Thanks!
Thanks!
The answer is yes. The final part must be contiguous for the Boolean to work. When I selected the base as well the Boolean works fine.
https://cad.onshape.com/documents/2105b62997584e0448fcadd4/w/384d01ce61f10e8764050913/e/e1ffd1a1902b808304b54d20
You can use the composite part tool create to treat the as one single part and then pattern them.
But you could also just pattern all the individual parts and then create a boolean in the end.
I have created an example of both here:
https://cad.onshape.com/documents/8bb6454e15fa8ced6d7507aa/w/1f261111f21d9a43bd16f8ca/e/a45b3bf5ad9c9e8f3ba738c2
Hope this helps.
PS: I would suggest to always reference my sketches to the origion or other reference geometry. Check sketch VESA holes
