How identify a tangent point?
fred_wildfred_wild Member Posts: 29
I want to draw a line perpendicular to a tangent at the point it hits the apex of a spline.  Can Onshape identify the point of tangency and place a point there?  Thank you.
    Sketch or 3D spline? What is your plane of reference?
  • fred_wildfred_wild Member Posts: 29
    In a sketch on the front plane.  Thank you.
    You could try drawing a vertical line down to roughly where the apex is, then add a normal contraint between the spline and the line. It might move the spline, but it will give you the apex point.
