Why does the pitch circle diameter outline never move with the gear when?
Every time I move a gear in OnShape, the pitch circle outline stays where it is. I'm not sure if this is even something to be concerned about, but I'd like to fix it.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    Transform only moves bodies, not sketches. In the gear feature there is an option to position the gear.
