Please help Boolean function will not work
in General
Hey please help.
How do I take the circle with the slope away from the main extruded centre so that a ball can rest in the middle?
Thanks
https://cad.onshape.com/documents/0db80d60b1488c08590fb710/w/81edab62c73323de051b3130/e/392c351f1fbffc2415e2b862?renderMode=0&uiState=
(I have no idea if this link is all you need)
Thanks
https://learn.onshape.com/catalog?labels=%5B%22Self-Paced%20Courses%22%5D&values=%5B%22CAD%20Basics%22%5D
Cheers
Glen
Christian. Welcome to OS and the forum.
The fix for your dish shape is straight forward. Simply change revolve 1 to remove and merge with all.
How ever, there are a number of of issues before getting to this stage that you'll likely want to get a handle on to make your experience with OS better. The number of delete parts is a bit of a give way. There seems to be parts drawn over parts that are confusing and extra steps to create wanted geometry. A trip through the self paced courses will help to clarify and reduce the number of steps needed to accomplish any given task. When the number of features are reduced to a minimum then keeping design intent clear and future changes will be much easier. See part studio 2 for an example of reduced steps.
https://cad.onshape.com/documents/165e9efd6b33408e6b3db138/w/a344f55a594869de9c304880/e/42b1060faefb02b4014bdf6e
