Help with a custom extrusion
willian_tamagi
Member Posts: 12 ✭
Hi folks, I'm new to the onshape software and cad drawing.
I'm trying to use the extrusion to remove the excess of the frame from my drawing, I tried to use the "Remove up to part" but I'm not manage to make it work.
What I'm doing wrong and what is the easiest way to do this?
https://cad.onshape.com/documents/3ffd866aec2bb976b59bb25c/w/7672397b32ce7e24d0299952/e/844995fde0223b81f98b66ba?renderMode=0&uiState=6527ed8115dc7605c78c3897
MichaelPascoe
Member Posts: 2,811 PRO
Welcome to Onshape @willian_tamagi!
Extrude up to part only works if there are no open gaps in the part. You could fill in all the holes that the extrude is detecting, or you could use the Boolean feature to remove the excess material like this:
https://cad.onshape.com/documents/3fdcc1ca3e15fbfd57233d76/w/12dd884b11268c3513b569c9/e/da6d1287bf...
RENDERCAD
________________________________________________________________________1
RENDERCAD
Thank you so much for your reply, I tried to use boolean like you used but without success
Here: https://cad.onshape.com/documents/b7b0edb7863a479eed28b238/w/49bf1b74a3577346f44802c1/e/f5da6038635a5271668a9837
thank you for your help Michael.
