Managing Onshape Drawing Revisions: Starting at Revision # for Migrated Designs
Hello Forum Members,
I've recently migrated some legacy 2D engineering drawings to Onshape and am now recreating and modelling these drawings within the Onshape platform. However, I have a specific requirement: I need the new Onshape engineering drawings to be at the next revision level, with the description "moved to Onshape" or a similar notation.
Currently, my drawing is at revision C. Since the Onshape drawing is a new creation, it typically starts at revision A. To align it with my existing revision level, which is C, and ensure that when I release the drawing, it advances to revision D, here's what I need to know:
How can I adjust the starting revision of the Onshape drawing to revision C?
Thank you in advance for your assistance.
What threw me off when I first updated the revision property was that the revision table did not update. It stayed at A. however once the release progress was completed. it then updates.
as the process is approved. Because we host the drawing application, release management, and the PDM system of record - we can do it this way.
You can set up custom schemes - by adding a text file with all your Revisions. This is in Release Management settings (at least in Enterprise).
For instance:
A
B
C
D
1
2
3
4
So when I release a drawing for the First time, I set the Revision to "1".. and it releases correctly. Then for subsequent releases - it looks at the list and increments appropriately.
Can't wait for Drawing Revisions to automatically jump to the correct start point in my Custom list @pete_yodis !
