Linear feature can not be applied, unclear reason
HI, I try to apply a linear pattern to multiple features inside a box. Interestingly, this works for most features, but not for 1 fillet.
I can apply the extrude by instance, that's fine, but I see no reason why the fillet is not working.
  • S1monS1mon Member Posts: 3,751 PRO
    If you include the pocket that created the edge, it would likely work.
