https://youtu.be/h2cV3EdhN3s
PD: I love the improvements in the drawings.
I simply love correcting the Diameter dimension feature so it does not continue with extra vertical line below the text. Such useful update for making drawing more clear and uncluttered.
Renaming Hole feature based on actual hole parameters is another quality improvement to keep better track of different holes and keep the Feature list more tidy.
Using Z-Datum in MC as a reference for Bridging curve is really cool.
Resize is just awesome, now I don't need to zoom out to see the extra options while selected several features.
What I would like to see added is attaching to extension lines enlarged. It will definitely help with placement of Surface finish symbols. Currently the snapping works only for Dimensions, but I would find it very useful also for extension lines from Datums, Geometric tolerance or Hole Callout.
You could create a copy of the Hole FeatureScript code, but I wouldn't recommend doing that. The reason is that you would have to update that FeatureScript every time there are changes in Onshape updates
We have a long list of capabilities that we would like to bring to many diverse industries and rely on the feedback of users to help us allocate resources. There are several mechanisms available to you to register specific detailed requests, but as a team we all read these and would love to ask what industry you are designing for and what your top 3 productivity needs would be?
Don't get me wrong. I appreciate every update, every 3 weeks.
However I don't agree that those features within the last couple of updates are "huge" or "wow". It is just something almost every mature CAD system out there can do.
I'm probably one of the biggest fans of onshapes new data management paradigms. It is a real game changer. However, despite of this unique feature most of old school CAD Users are afraid of changing their beloved fully functional CAD System. And reading the list of feature requirements (available in other CAD), I think there is quite a lot of work ahead.
My personal favourites would be:
you see...there is no time to slow down. It is a lot of work ahead.
Twitter: @BryanLAGdesign
I just made it Yellow, as a pending status. Once it Turns Green it will be an official square.
When I've written some featureScripts there are certain things that won't update until you delete / re-create the feature under the new version.
The feature name is one of those things.
I just found out that if delete the name it will "auto-name" itself, and if you edit again, the name is set to "#featureName" so you can also rename it to that to set the name to "automatic".
I tried some other features and they just show up as "?" when set to "#featureName", I'm guessing there is a way to write a feature so that it auto-names itself that way... Some of the FS gurus out there should look into it
Take your time onshape crew. We can wait another week or more if we need to.
Updates are alwayd Gold
