Assembly to 3d print
in General
We have developed a full sized shipping container in work with machinery inside,
I have drawn these up in multiple part studios and different document and the whole thing is a mish-mash of ideas. - I'm still learning and haven't learnt the right order to do things.
I also imported a file of a shipping container to begin with that had parts everywhere when I looked at the part studio.
Now it's complete and working I wanted a model of the overal item to be printed to have on the shelf.
I've exported the assembly,
And imported it again into a new document so everything was together. Part studio has once again put all of the pieces into one pile.
what I want to do is either print a solid object as an ornament or to a make a shell of the entire container with a cut out in the top to store business cards - or something along that idea.
I will look online to see if I can get it printed
if I can get a model working first.
What I need to know - can I bring all the parts from an assembly into a part studio, to join them into a solid block, which I can then extrude a hole into. Or get printed as it is,
There are loads of individual parts and want just the basic outer faces.
Can anyone help please?
the computer fails to do the copy in place
and the simplify failed too
and no parts have been created
What happens with the "copy in place"? Is there an error of some sort? If you select a lot of things it can take a moment to generate the parts, I would try selecting just one part to start with to make sure it's working and then ad more to your selection...
I haven't really used the "simplify" feature myself so I'm not sure what that means... Have you watched the "instructions" video for the simplify, I do remember there are a number of steps to take to make it "do something".
I'll look again when I'm home
I know the computer froze first of all
it was running very slow trying to select all the parts
I did watch the video for the simplify which I believe I followed correctly
maybe because there's so many parts or when I imported the original file maybe something doesn't meet there
you may be able to help show where I may be going wrong
i have tried doing it in sections now
and these are working but trying to Boolean the seperate sections now has thrown a new error -
"Boolean operation would result in non manifold body"
what does this mean and is there a way to work out what part is the problem
thanks
