Peak Stress Value
Dean_Gardner
Member Posts: 114 PRO
in Simulation
Is it possible to find the absolute peak stress value in simulation? without going on a mouse journey...
Is it the figure to the right and left of the legend? I.e. -80.4 and +80.16? If so, why are they so far from the autoscale limits, -21.9 and 22.34?
Matt_Shields
Member, Onshape Employees Posts: 899 PRO
You can click the blue text and type in your own maximum. Is 22.3 the largest it will let you type?
GregBrown
Member, Onshape Employees, csevp, pcbaevp Posts: 371
There is a reason we automatically scale the legend to be something other than the absolute min/max of the results... And that is the (reality of the) presence of singularities in the model. In the case Matt shows above, the infinitely sharp corners of the triangle supports will cause stress singularities, and thus the theoretical max stress of infinity will not really be helpful to anyone. So we take a statistical analysis of the element stresses and determine what is the best max/min for the legend in order to give a decent visual representation. You of course need to verify the locations/reasons for singularities to be present, and you can of course adjust the legend to whatever values to like.
2
