FeatureScript Library (New Custom Features!) 💎
MichaelPascoe
Member Posts: 2,703 PRO
Introducing the
CADSharp FeatureScript Library
www.cadsharp.com/featurescripts
This library is compiled of custom features written by CADSharp developers, completely FREE for you to use. These custom features demonstrate only a few of the neat things we can create for you using Onshape's native FeatureScript language. We specialize in improving your CAD efficiency; if you don't see what your looking for, contact us!
Currently, the library is made up of features from the following CADSharp developers:
- @caden_armstrong
- I'm sure we'll see @Jacob_Corder on here eventually
- @Konst_Sh | @Konstantin_Sh | @konstantin_shiriazdanov
- @MichaelPascoe
Also, thanks to anyone else who may be involved in the creation of these custom features.
Stay tuned! More custom features will be added regularly.
How to add a custom feature to your toolbar?
Many of the current features in the list you are familiar with, but we have new ones as well as more familiar ones coming soon.
Zone Delete has been added to the CADSharp FeatureScript Library!
Zone Delete is capable of deleting entities based on a specified region.
Useful when patterned parts must stay in or out of a set zone.
Imprint has been added to the CADSharp FeatureScript Library!
Imprint places a sketch onto your part via extrude, offset surface, or split face. If you store sketches in your custom frame library, the feature will remember your sketch selection for future use no matter which document you're in! This is useful for simple logos, icons, and other enclosed sketches like words.
Transform Pattern has been added to the CADSharp FeatureScript Library!
Transform Pattern was written by @Konstantin_Sh, a CADSharp developer. It has been around for a while but we are thrilled to display it in our library! This feature is useful when you need to pattern entities or features in a non linear or non circular way. Looks like @Evan_Reese made that legit icon for it
edit: would it be possible to use transform pattern to the ponits defined with the 3D point custom feature? This would allow to copy a part to specific locations in space. adding instances when the numebr of points within the feature increases.
@stvnvl_8501 Glad you like it!
I pushed a quick update for you that will allow the selection of composite parts as targets. Using the Polyline option in Evan's Freeform spline feature should achieve similar results to what you are trying to do.
https://cad.onshape.com/documents/6b982e3c0a039b6d40984f18/w/a8758b2ada19ff853f3529f0/e/cadd3ce522252...
Measure cut list has been added to the CADSharp FeatureScript Library!
Measure cut list was written by @MichaelPascoe , a CADSharp developer. We have pushed some exciting auto measure updates to this feature! This feature is useful when you need a table of measurements from your parts in the part studio.
Tips:
Zone Delete has been updated!
Has been added to the CADSharp FeatureScript Library!
This custom feature helps analyze fillet failures by splitting the part until it locates the failure region.
This custom feature creates a grid for down stream sketching.
This custom feature has the ability to handle composite parts as well as standard parts when performing boolean operations.
Query Finder.
This custom feature saves selections for downstream selection automation with features that contain the
This custom feature is multiple features in one: (Extrude, Revolve, Sweep, etc…), which has advanced suppression control via logical statements or feature list dependencies.
It is also equipped with the
Query Finder for selection automation.
