Can I set a Feature UI preview tolerance with Featurescript?
EvanReeseEvanReese Member, Mentor Posts: 2,851 PRO
I'm working on a feature that uses refractive indexes of various materials, and one of them defaults to 1.00027717 (which is air), instead of 1 (which is a vacuum). When you just look at the feature UI though, all of it is rounded to 1 until you click the field to edit it, so a user wouldn't understand what the default number actually is. Is there a way I can control how many decimal places to preview?
  • glen_dewsburyglen_dewsbury Member Posts: 1,289 PRO
    The only way I know of is the work space units and changing decimal places there. Can you temporarily change the work space properties while in your function?
  • _anton_anton Member, Onshape Employees Posts: 521 image
    Crude workaround, but you could use a string parameter, which will display your value literally, and use stringToNumber in FS.
  • EvanReeseEvanReese Member, Mentor Posts: 2,851 PRO
    Thanks for the ideas. Either of those are even less desirable, so I'll roll with it as-is, but very much appreciate the input
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    Perhaps you could display an info banner with the actual number with a description?
