Silhouette Curve
in General
Is there such a way of generating a curve over a part around the perimeter outermost edge, in the current view or orthogonal view? I need to create a split-line for a tool over a complex shape. Other packages call this a silhouette curve. By the way, the curve may not be planar if the thickest parts go in and out of the screen.
https://cad.onshape.com/documents/2dd6d1fe1d89637ea7fc1963/v/355c002924517068fb137860/e/88ee772b21fefde5d657f2d1
https://cad.onshape.com/documents/5370e14526610dcdfe34a4a4/v/cf7da8ecbedcc162cc04499f/e/95f4e29d028812779e99a15f
Perhaps I'm going about it the wrong way?
P.S. This might be thread-jacking, but I hope it's somewhat relevant in the sense that generating the curve is usually associated with using the curve.
Improvements to Onshape - June 29th, 2023 — Onshape
@kenn_sebesta167
You should check out this thread for a couple of feature scripts which will project a part onto a surface:
https://forum.onshape.com/discussion/11011/silhouette-outline
