STL Import can not select edge geometry
aiden_tanner263
Member Posts: 2 EDU
Hello!
I am trying to import an STL file to be used as a solid body. When I import, onshape recognizes and imports the STL as a single surface with one large open face; however, I can not select the edges of that face for any of the "fill" surface modeling tool. Despite this, I can still select the edge when I am not in a tool menu, but as soon as I try activate the tool and try to select the edge, the edge is unable to be selected.
Is this an issue with the STL file? Is this an issue with the import?
Thank you for any insight!
1
if the stl is open, you get errors, but can still cut/split it. and use the lines in a sketch (and get more errors). using these allows for use of the fill feature.
DISAPPOINTMENT It`s really terrible that this software can`t do much… I`m so disappointed… will have to fire up my 7-years-old vm… such pity… wasted bits and bytes… I tried all solutions (all solutions provided by a Google search).. Nothing works.. and if I try to select vertices, I NEED TO CLICK EVERY SINGLE ONE OF THEM, you can`t use selection tools…. my god… I`m back to 360….
The problem is that the import is not always correctly performed… Had some mixed experience today, almost fired up my 7-yars-old vm (to avoid the 360), but you sometimes have to uncheck and mark again the "Import Appearances" and "Allow faulty parts", even though the imported shape is not faulty.. but otherwise you couldn`t slice it.
