How to apply full round fillet?
nick_gholaminick_gholami Member Posts: 7 EDU
Hi,
I am trying to use the full round fillet on the dark part.
For some reason the fillet will only be applied when i extrude the part my a certain height. In this case I have to extrude it by minimum 2.9 mm.
Any ideas on how to extrude it less, and still get the full round fillet?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,970 image
    Use revolve instead of extrude - then you can sketch the fillet you want.
