Define the surface distance between two bending pockets
Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 431 PRO
edited October 2023 in General
Is there a simple way to define the surface distance between two bending pockets if the angle is not 90°? In the following pictures, the distance between the two marked surfaces should be exactly 10.2 mm. At the moment, I am slowly adjusting the length of flange 1 until the surface distance is exactly right. This can go down to the fifth decimal place....
Of course I could build the sheet metal model differently from the beginning, but I already have some features planned in this part and no time to do it again. It would be ideal to be able to say afterwards what the distance between the two faces should be, so that the flange length calculates itself for angles above and below 90°.
How can this problem be solved? Do I have to try it out measurement by measurement to see if it fits?
Best regards,
Axel Kollmenter
