Extruding from a curved surface
I am working on modeling a violin top. I have successfully developed the top surface. My next step is to add the graduated thicknesses to the backside of the surface. I am able to draw a sketch of the shapes that represent the various areas of thickness. My question is, is there a way to extrude from The bottom of the surface using a sketch on a plane above or below the surface.
  • S1monS1mon Member Posts: 3,804 PRO
    Yes. There are a lot of options in the extrude feature which should be able to solve your request. It would be easier if you can share a public document.
  • aaron_nguyaaron_nguy Member Posts: 6 EDU
    There's a 'thicken' option for surfaces.
