Can you please check what is causing the nonmanifold geometry
jakub_šlahorek162
Member Posts: 6 ✭
Hello, I have just completed my first 3D model and when I load it to Bambulab, I receive a waring of a non-manifold geometry. Cura shows that the problem is in the marked regions. However, I do not know how to fix it. Would anyone be so kind and point out the problem please? Thank you! Jakub
https://cad.onshape.com/documents/5df2367fcf8d4801e570bc6a/w/376f9c6a8964b17a368928ab/e/4bcc4dbca50716b3f11efef3?renderMode=2&tangentEdgeStyle=2&uiState=653cf4843cd5453e9df839de
glen_dewsbury
Member Posts: 1,228 PRO
If your goal is to include what I see as dark blue surfaces then you will need to enclose them to make them solid and part of the main body. I'm sure the slicer doesn't know what to do with a 'surface'. My sample as exported as stl then imported to see in a part studio.
https://cad.onshape.com/documents/212f393aed3155c6991b49d6/w/830f93841641863702fe566b/e/bebe993a209ef2f18fdfe5af
1
https://cad.onshape.com/documents/5df2367fcf8d4801e570bc6a/v/5f3ba1dd145270fc7fa7e315/e/4bcc4dbca50716b3f11efef3?renderMode=0&uiState=653f9a8077edcf48d080192c
Thank you for your help!
Hello, Glen, thank you so much! Obviously, I did not know how to properly enclose the area. Not only you solved my problem but also taught me something new. Thank you!!!
