Why Doesn't my Variable Studio work in this document assembly and part studio??
in General
I have tried to make this work several times but its just not seeing it. I must be missing something. I'm working on a desktop computer.
https://cad.onshape.com/documents/9e3aa08c3a81094e04655bb9/w/c7595b120fd1cc04231cd04e/e/f858782cd65b10a87dfd3315
https://cad.onshape.com/documents/9e3aa08c3a81094e04655bb9/w/c7595b120fd1cc04231cd04e/e/749e4ac85a7cc43a4872e772
For reference, if you look at an overridden variable in the variable table, you'll see an info icon that points this out.
Hey Paul. This may be a little confusing I realize since there are 2 or more lists available to you. As many variable studios can be created as needed and can be available through any part studio/assembly.
When you add variables directly in a part studio they are in the feature list and will display when you ask to see variable table. This is a good way to see all variables added to your feature tree in one place without searching through an extended feature list.
There is an other way to accomplish this through he use of a separate "variable studio" which will also display when you ask to see variable table. I chose this method because it is also available when in an assembly. See "Hello Variable Studio" from inside the assembly.
Each method has it's advantages. In this example changes to "Hello Variable Studio" will show through while working in the assembly as the part studio is updated. Note that only one of these parts is updated while in this assembly since some of the variables are local to part studio 1.
https://cad.onshape.com/documents/9336c6b64bbd03c49cf1dc6e/w/29473ede6a8f6e7ad8f7e34c/e/7f8c70364a03ed5567a513ea
