'Some External References Are Missing'
larry_hawes
Member Posts: 478 PRO
in General
..which I can eliminate except for the origin's 'Use' reference. Can't provide the document but this doc has more than one reference like the one shown in the pic. Can't find a way to delete the ref. at the origin. The sketch behaves OK but is always red. Any hints?
Thanks
Thanks
Twitter: @bradleysauln
Tried hiding everything with no luck and right clicking the red 'Use' ref box gave a delete sketch entity option but it would remain. Turned out in this case that selecting the point that was ref'd and deleting it did the trick. VERY confusing as typically right clicking the red ref box and deleting it would solve the sketch but this time it took deleting the point itself. Probably expected behavior but had me flumoxed for a while.
You can select the constraint and press the delete key (or backspace key) to delete it. I don't think there is a way apart from deleting the actual point without the keyboard.
Sometimes it might look like it's not doing anything but I there might be more than one "on top of each other" and I've had to delete several times before it went away...
A context "delete all broken references" would be helpful in these cases...
