Enclose with a Hole
in Drawings
I am trying to make a space bounded by surfaces into a a solid so I was planning on using the enclose tool. However, This space has a hole running through it and so I am not sure how to use the tool if there is a hole. Also I cannot use the sweep function or something like that because the hole varies in size from very large to kinda small.
https://cad.onshape.com/documents/1f19e48616bb3d731dbc2714/w/2e51a0d5378a2b76735bbd32/e/6705b456d1bef20c207912e4
I am making a car. That is it above and the partI need to make solid is the front part but as you can see I have a channel running through the front.
https://cad.onshape.com/documents/8dd42a3b5eae5998ff2c737a/w/8a1cb42dadde04ec2c65b551/e/1ea98d037600eefbb43de1a8
Use this one
