After importing a file and transferring from millimeters to inches my scale to my project too big.
I have tried to change dimensions but cannot. How can I scale down a ratlore that is over 2,000 in and I want it don't only be 5.5 in.?
  • Nath_McCNath_McC Member Posts: 136 PRO
    edited November 2023
    Hi @damon_bawek
    Something doesn't add up as 5.5in is only approximately 140mm, and even if the conversion is 1mm to 1in, that is only 140 inches.
    I have a couple of questions:
    What format are you importing?
    How are you converting/transferring units?
    Can you use the transform tool?
    Can you share a link to the file?
  • damon_bawekdamon_bawek Member Posts: 4
    STL
    I push the inch button
    cyber_rat_v1.stl - Copy
