How to create the next part in this (parametric) model?
jezmck
Member Posts: 12 ✭
I have got this far with modelling a Counter Flap Catch, with the intent of it being a 3D print-in-place model, but I am now a bit stuck trying to work out how to continue.
I suppose I need to add another sketch, offset from the inner side of the slot somehow, to continue with the grey (moving) part.
Any help or suggestions will be massively appreciated!
Here's my model; https://cad.onshape.com/documents/bb4a15d567379350fd092f5f/w/ea21c00624b8a4a6d9210643/e/515d572ae50f5cd18abd8824?renderMode=0&uiState=654a70c7a6c4437fa7051ce9
and a photo of a real one.
nick_papageorge_dayjob
Member, csevp Posts: 1,093 PRO
You should make parts symmetrical about the default planes whenever possible. On Matt's copy, he modified your first extrusion to be symmetrical about the front plane. You'll use that plane many times over in this project and in future projects.1
https://cad.onshape.com/documents/33d518e5aa4df1feae0a6096/w/d2bcf6f3ad006016bbf8f438/e/52efd79eba42acb61451eb79
But this is also something for you.
https://learn.onshape.com/courses/fundamentals-multi-part-part-studios
