Can discussions be deleted?
sean_trainor1988sean_trainor1988 Member Posts: 15 ✭✭
I've just tried to remove a previous discussion which I don't think is relevant anymore, but I can't see an option to delete it.
  • S1monS1mon Member Posts: 3,961 PRO
    I’m sure the admins can delete whatever, and you could DM @NeilCooke but you can also just edit the posts that you made to reflect that they are not relevant (assuming they aren’t much older).
