Plane visibility (eye icon) not available when in Sketch mode
joscha_mh
Member Posts: 4 ✭
Hi all, when I enter Sketch 2, suddenly all other sketches and planes are hidden. I cannot display them since the eye icon is not shown. I need to display to create an intersect... Thanks!
S1mon
Member Posts: 4,063 PRO
The feature tree is in order of rebuild. When you edit Sketch 2, the only things available to reference are Sketch 1 and the default geometry (the origin and Top, Front, Right planes). If other things aren't dependent on Sketch 2, you could drag it down the tree to re-order it later after whatever you want to reference.
