Issues with face blend tool
Hello, I am having issues with the face blend tool, I am trying to blend the selected sides to the base so it creates a curve. I have them selected but I still have issues.
https://cad.onshape.com/documents/c4d22f1e75e85dcf703b04ca/w/c66719a64fcd3c8113d22081/e/bea05b17b690a31c778a84a4?renderMode=0&uiState=654dfc8e1bf8eb053f02176b
You have three parts, and it's not clear if that's intentional or not. Face blend can create a blend between two parts, but only as a detached surface. If you want a solid blend, the input surfaces for the blend need to be on the same part. Your extrudes probably should be using "Add" instead of "New", or you could Boolean them together.
